12-16-2024 01:57 PM in
Galaxy S- Mark as New
12-16-2024 08:58 PM in
Galaxy SHere are a few steps you can try to stop the system notification sound while playing or changing music on your Samsung S24 Ultra:
Do Not Disturb Mode: Enable Do Not Disturb mode while listening to music. This will silence all notifications. Go to Settings > Notifications > Do Not Disturb and toggle it on.
Sound Assistant: Use the Sound Assistant feature in the Good Lock app. This allows you to customize sound settings, including muting notifications while playing music. You can download Good Lock from the Galaxy Store and configure Sound Assistant.
Notification Settings: Adjust the notification settings for the music app you're using. Go to Settings > Apps > [Your Music App] > Notifications and customize the notification settings to minimize interruptions.
If your question has been answered, please press the "Accept as Solution". You will find in three dots to the right of my comment.
