Sound assistant not available for my phone
(Topic created on: 12-09-2024 06:18 AM)
zohaibs21
Any one can help I bought s21 because it is update able to one ui 6.1 that has awesome 👌 features but unfortunately I am not able to enjoy this version 😢 😕because my one of my most favorite features is sound assistant that is missing in good lock
Can any one help me about this and I request Samsung to fix this issue for my phone please 🙏
4 Comments
Techapp
Sound assistant is not available for s21 series or before it's only circle to search that is available for that
zohaibs21
I saw many s21 phones have this and s21 fe also have this
Didionpc
Here are a few steps you can try to resolve this issue:
Check for Updates: Sometimes, Samsung releases minor updates to fix issues. Go to Settings > Software Update and check if there's an update available.
Good Lock App: Ensure that you have the latest version of the Good Lock app. You can update it from the Galaxy Store.
Sound Assistant Module: If the Sound Assistant module is missing, try reinstalling it. Open the Good Lock app, go to the "Family" section, and look for Sound Assistant. If it's not there, you might need to download it from the Galaxy Store.
Contact Samsung Support: If the above steps don't work, you can contact Samsung Support for further assistance. They might be able to provide a solution or escalate the issue.
If your question has been answered, please press the "Accept as Solution". There are three dots to the right of my comment.
zohaibs21
The steps on above you tell me to do is also done and every thing is updated.
I have already installed or reinstall good lock app 2 or 3 times 😂 but it still not
The only problem sound assistant is not missing other apps are not still working properly 😒
