S9+ Battery Drain issue after Android 10 upgrade
(Topic created on: 03-11-2020 09:45 PM)
SarmadSaleem
I need suggestions how to resolve the issue of Battery drain fast after Android 10 upgrade in my S9+ as the issue is really disturb my daily routine usage. Anyone have fruitful suggestions are warly welcomed. 🤝🏻
7 Comments
lastAngel
السلام علیکم
Format the mobile once۔
SarmadSaleem
walaikumasalan bro any suggestions without formatting plz bcz very hectic option
Laveed
first change the battery option to 'optimised' ....
Laveed
my s9 faced the same issue...and i did it through changing the battery option to optimise...then did it again to the normal...now the battery has become better than before the update even...
SarmadSaleem
tell me with screenshots
AhsanA
Hi, Thank you for your interest. Please go to mobile settings, select the option 'device management'. Make sure your device is 'optimized'. After that open 'memory' and 'storage' options and clear them. This should help to improve the battery time of your Samsung smartphone.
Dhobi
Please contact Samsung through Twitter. They will respond and resolve.
