S24 Ultra Power Button Loose
(Topic created on: 06-17-2024 06:41 AM)
Nawazkhan3
I recently acquired a brand-new Samsung S24 Ultra, which unfortunately shares a recurring issue with my previous S24 Ultra device. Despite exercising utmost care, the power button became loose and tilted towards the upper side, noticeable to the touch, after only two weeks of usage.
Prior to this, I had purchased a pre-owned S24 Ultra that exhibited the same problem, leading me to believe it was a result of the previous owner's handling. Consequently, I returned that device and opted for a brand-new, sealed unit.
Regrettably, despite my transition from iPhone to Samsung, I find myself questioning my decision due to these persistent issues.
15 Comments
AhmadJs69
Are u using an aftermarket case?
Nawazkhan3
No. I'm not using anything. Though the button is working properly, it is tilted.
Nawazkhan3
If one side of the power button is pressed, it bends. IMG-20240617-WA0036_1000092258_1718632510.jpgIMG-20240617-WA0035_1000092257_1718632507.jpg
aakashnawab7
Samsung k power button aese hi hote hn.
Less choppy, or removable.
Keep using, no issues. If you still not satisfied, go for a good case.
Nawazkhan3
Thank you brother. I am just confirming if anyone else is facing such issue.
I am new to Samsung and the button was initially okay like an Iphone. Now, it is loose and very irritating for me.
If this is common to everyone, then this is not an issue at all. If I am the only one facing this, then better to consult Samsung Service Center as the phone is brand new. Thanks
aakashnawab7
It's not loosely actually. Samsung provide replaceable buttons, that's why they're like that.
You can see the videos on internet also.
Search for durability test for S24 ultra. JerryRigEverything
SerK
I have same issue. Just 3weeks old. Bought it brand new. Had the same issue with my S10 but that was after 3years or so. I get your frustration
Sektor
Same here. Bought a brand new S23 FE and it had the same issue, with the power button being loose and wobbly, but it is no big deal
tanaytejush
  • Bhai apke phone mai bhi aisa hi power button hai kya ?
