S23 wifi issue with wifi-6 device
(Topic created on: 10-02-2023 03:06 PM)
A2gc
60-70 % s23 users facing issues connectig to wifi-6 device, because now worldwide every where the new wifi devices are wifi-6 enabled by default, and after contacting other users and using search engines, its confirmed that its s23 will not work fine connected to a wifi-6
11 Comments
user9992112
Why?
k22CE003muet
Wife doesn't work properly what steps should I take to proper wife network
Bonita143
Have you tried using different wifi?
k22CE003muet
Yes it works properly in other devices but except mine one
Bonita143
Check your wifi modem settings then... there are new devices with different settings so get your Internet provider on call and explain the issue
A2gc
unfortunately there is no solution, except you disable the wifi-6 option in Wifi modem,
criminaLmodi
Wife or wifi,?
k22CE003muet
So funny absolutely Wifi
criminaLmodi
But i read WIFE not wifi, look at Your 1st mesg🤭
