S22 Ultra unlocked (U1) Wifi Calling issue
(Topic created on: 07-29-2023 08:31 AM)
mFahadAzhar
I am having an issue on wifi calling on my second device S22 Ultra connected to Jazz network on e-sim. I am not able to connect it in anyways. Tried number of diff methods (Network reset, Phone reset, Factory reset, wifi router settings, clear cache and what not) but no luck.
My second phone A35 connected with same Mobile network and same wifi. But its wifi calling working pretty fine.
Anyone has the solution, do help me out plz.
5 Comments
aakashnawab7
Jazz sb sims pr Wifi Calling nhi de rha. Kisi sim pr enabled hai, kisi pr nhi hai.
Kuch sims pr recently active kia h, us se phle active nhi tha. Meri sim pr VoLTE 1st day se aa rha tha. Lekin WiFi calling last week aaya.
Aapki ESim hai is liye aap different sims try bhi nhi kr skte. Is liye iska filhal koi solution nhi h. ESim na hoti to 1 try ye ho skti thi k aap Wifi Calling wali sim lga kr check kr skte the. Lekin ab wo bhi nhi ho skta.
Baqi Jazz care aap rabta na krna. Q.K unko khud nhi pta k WiFi calling kisk pas enabled hai, or kisk pas enabled nhi h. Wo evein baato mei ghumate rheinge.
mFahadAzhar
True...
user9992112
Its US model, you will have to wait for new update
zafar7172
Is it patched or CPID approved? In dono mein issue aata hai.
mFahadAzhar
No. Offically US warrent with PTA approved.
