S23 FE Battery draining issue solved
(Topic created on: 01-22-2024 06:50 PM)
imBilalQamar
Dear S23 FE users kindly master reset your smartphone because there is a bug in 1 January 2024 Sofware update after reset battery is working fine.
Take your all data in Usb, Otg, Computer PC, laptop or External harddrive.
Thank you.
14 Comments
atifmughal662
Mera to 1st January se pehly ka yehi issue
imBilalQamar
Aap apne mobile ko master reset karain Android 14 ki upgrade ke saath kuh bugs hain woh remove ho jaayain ge.
atifmughal662
Apni battery ki stats btayen
imBilalQamar
Meri smartphone ki battery status raat 11:30 pm 100 % charge kiya tha subha 92 % tha normal hai.
atifmughal662
Screen time
hamrehman
I have purchased new phone in jan but still i am facing battery draining issue.
imBilalQamar
Yaar 20 hrs battery backup normal hai matlab raat 11 pm charge karta hoon majn toh agle din to full use karoon matlab continuously musalsal toh shaam 4 pm dobara charge karta hoon agar gaming na karoon movies na deekhon phir pooray 20 hrs battery chalti hai.
imBilalQamar
I have noticed battery drain from yesterday then I read the comments mostly people are facing battery problems after January 2024 security update.
S23 FE is a great smartphone from Samsung. With every upgrade some bugs arrived, and these bugs are normal I have an iPhone last upgrade I have received ios 17.3 with full of bugs its has a lots of issue.
I also master reset that iPhone then phone is working fine.
Every company's OS have some bugs Xiomi, realme, oppo, nothing phone every brand OS have bugs. But Samsung deals with problems via Samsung member app.
MJ20
I have Upgraded it to Jan Update and Also Did Wipe Cache Partition via Laptop and Yesterday It Gave me 5 hours 53 min Screen on Time with 74% Battery Usage out of 100 % ,That's Excellent Performance, Just Fix some settings like Refresh Rate, Use Battery Optimization and put Unnecessary Apps To Deep Sleep ,It works Fine.I Think Hard Reset Not Required.
