S22 ultra mobile network issue
(Topic created on: 08-12-2024 04:14 PM)
Hassan--3
I have this s22 ultra esim imei patch or whatever you would call it - the call and message even data only works when 4g with full signals - other than that it doesnt show 3g or 2 g straight away no signal ☆ ps see the pics help needed .
Even with signal it drops off randomly
sajidwrites58
My phone snapdragon see my profile posts
Hassan--3
Do u have csc code I want to change
sajidwrites58
user9992112
The first thing you need to do is to get a replacement esim and only then we can find what the real problem is. If you don't want to do so then simply turn on wifi calling and that will keep you connected on the go (currently available on Jazz only).
Hassan--3
Not network problem in my opinion the signals on my phone keeps droping off while i have another sim zong works flawlessly on my other phone with near to full bars
user9992112
Download DVS app from playstore and check what does your IMEI status say for both SIMs. Maybe PTA has blocked the second IMEI
Hassan--3
Okay theres is a confusing thing about my phone - the esim imei is of q mobile l1 and the real imei is non pta but somehow my phone runs both sims for around 1 month
Hassan--3
Real imei means physical sim
user9992112
Yep, I knew it. It is a cpid phone and the put a very bad imei and didn't do it on both sims that is why you get the error "not registered on the network."
Hassan--3
Even when i have a single sim it doesnt work you have to go outside in open direct connecting to tower to actually even send nessages
