Rizman
04-13-2025 02:29 AM in
Does anyone know where to get official battery replacement for Samsung S21?
I have tried the service centre they told me to keep my phone with them till the battery arrives. Having an e-sim that's completely out of the question. And it may take 3 days or 2 months depending on the battery available.
What other alternatives do I have in Islamabad?
2 Comments
HamidHimmat
04-13-2025 03:54 AM in
If the service center doesn't have how local workers will have it, wait for it or go with a copy version
Rizman
04-15-2025 11:40 PM in
The service centre will import from out of country which might take months to arrive.
They said that there's no certainty weather it will be available locally or not. Only after you have submitted your phone with them then they will tell you how long it might take. Which imo is pretty stupid.
I asked them that if I can pay for the battery and when it arrives I will submit the phone. They simply said no.
Local centres do have the battery available. They refer it to as "Pull-out" battery ( battery that has been pulled out from a phone) which makes the battery health pretty dubious and uncertain. But, that will take a maximum of 6 hours to replace and I will have my phone back in hand by the end of day.
