Overheating solution
(Topic created on: 03-25-2024 12:13 PM)
Ao4e
My mobile galaxy Ao4e has start overheating and also have so many glitches after installing the recent software.Is anyone have a solution of this ? So plzz help me
Thanks
2 Comments
ASIM-ANSARI
Bro summer is start so won't worry
RANA_NAJAM
Try a factory reset and configure your phone again. Uninstall unwanted apps. Use fast charging only when needed, and use a branded charger and cable. Avoid using the phone while it is charging. Remove the back cover or case and see if you notice any difference.
