Resolved! Solved
Brought an s22+ but it heats upto 43 degree and drain battery while normal usage
(Topic created on: 06-05-2023 01:19 AM)
talha13
Temp goes upto 43 degree while playing fifa soccer and also s22+ consumes a lot of battery wile normal usage and in normal usage temp is 37 centigrade
Resolved!
18 Comments
talha13
Approx 28-32
Bro normal hai meray around 40 hotay hai indoor mobile main obviously. Bus jitna kam ho use karo possible time power saving use karo forgot experience. If you care about battery or health. Forget to use in direct sun light. Also battery temps 40 say nichay hi rakhna especially while charging. Disable fast charging and also engage protect battery. Use in front of air cooler or direct with fan. Or cover remove kr k use krna atleast at home. Baqi tum apni routine dekht kr kuch months k liyay kuch compromise kr lo experience ya battery health or whatever
Saadi121
Battery temp 25 py best hota ha 40 py saturated hota means battery bohat jaldi kahrab ho jati ha
So maximum threshold bataya hai. 10 to 40
Saadi121
Bro threshold b 40 ni hà
Charging ka bol rahay hoo naa
BTW solution mark kr dena 3 doto pr click kr k reply k oper hai
thisissheraz
Outside se 6 7 zyada hi hota
MubashirIqbal
Default s22 ultra issue dur to its processor. So don't try to play with it . Overall issue
