Resolved! Solved
Brought an s22+ but it heats upto 43 degree and drain battery while normal usage
(Topic created on: 06-05-2023 01:19 AM)
talha13
Temp goes upto 43 degree while playing fifa soccer and also s22+ consumes a lot of battery wile normal usage and in normal usage temp is 37 centigrade
2 Solutions
Bro normal hai meray around 40 hotay hai indoor mobile main obviously. Bus jitna kam ho use karo possible time power saving use karo forgot experience. If you care about battery or health. Forget to use in direct sun light. Also battery temps 40 say nichay hi rakhna especially while charging. Disable fast charging and also engage protect battery. Use in front of air cooler or direct with fan. Or cover remove kr k use krna atleast at home. Baqi tum apni routine dekht kr kuch months k liyay kuch compromise kr lo experience ya battery health or whatever
MubashirIqbal
Default s22 ultra issue dur to its processor. So don't try to play with it . Overall issue
18 Comments
How is the temp outside
talha13
In normal it is very slightly high while gaming it gets excessive hot upto 43 degree
Did you buy it used or new
talha13
Used
Adil00
Which model do you have exynos or snapdragon??
I have Samsung S22 Plus USA Snapdragon variant mine working perfectly no any heating or draining issues or battery timing excellent.
talha13
Snapdragon Korean variant
Bro outdoor to normal hai indoor temp kiya hai waha Screenshot_20230605_174614_AnTuTu Benchmark.jpg
Kiya air conditioner laga hai
talha13
No
