Bluetooth problem!!
(Topic created on: 08-05-2022 01:16 PM)
Komail_Ahmad
My phone connects with my Bluetooth device normally, but when I play nothing for a while on it after that when I play some music it glitches, like the music cuts overtime.
Any solution
10 Comments
Saadi121
It's noise of your headset may be its local and have not ANC
Komail_Ahmad
No it's genuine, it worked well on my old phone!
Saadi121
Bro it's differ from model to model
Komail_Ahmad
I don't understand??
I also told about this issue to the Samsung Help assistance, they recommended me to bring my phone for hardware diagnosis!
Roxela
My internet got disconnected from my phone after every 2 mins automaticlly. Any solution?
Komail_Ahmad
If WiFi keeps disconnecting on Android, that’s probably not a big problem since you can fix it with just a few clicks most times. However, it could be annoying when WiFi disconnects frequently on Android, especially when you need to watch an important live stream or download a time-limited file.
Here are some 10 common ways that might fix the issue!!
1:Restart your phone
2:Remove and reconnect to the network
3:Forget old/other networks
4:Restart your Wi-Fi router
5:Move closer to the WiFi network
source
6:Try switching the router's AP band
7:Disable network auto-switch
8:Reset Wi-Fi, Mobile & Bluetooth settings
9:Update your phone and the router’s firmware
10:Disable apps conflicting with the Wi-Fi
Roxela
Thanks alot sir
Komail_Ahmad
Don't mention it
Just lemme know if it worked
Roxela
It worked man thanks
