Battery stats stopped showing
(Topic created on: 01-04-2021 01:33 AM)
Hassan33317
Can anybody tell me what could be the issue?
The battery stats stopped showing. I didn't change the battery or anything
Phone is S20+ 5G OneUI 3.0
Update: found a fix.
15 Comments
jawadh
after one ui 3.0 update.
battery stats will show thw data from last unplugged fully charged.
so it will reset data once the battery is charged up to 90% or more.
maybe this is the reason
Hassan33317
it used to show on one ui 3.0 but idk it stopped showing all of a sudden.
iarshad212
just check the device care update so u will see the best 👌
Hassan33317
hello. i just checked, its up to date.
iarshad212
First clear device care cache then device health cache
Hassan33317
did that. it's already on latest version.
iarshad212
I did same. go back to normal
one ui 3.0 s10 lite apk phone 📱?
iarshad212
check this
Hassan33317
phone is s20+ 5g. that's exactly what I am not getting. I've tried to upgrade it manually via apk and it doesn't install the apk.
