Battery stats stopped showing
(Topic created on: 01-04-2021 01:33 AM)
Hassan33317
Can anybody tell me what could be the issue?
The battery stats stopped showing. I didn't change the battery or anything
Phone is S20+ 5G OneUI 3.0
Update: found a fix.
15 Comments
iarshad212
https://youtu.be/MAcxdNOXHyo
watch it nd do the same process u will get 💯
Hassan33317
thanks man.
iarshad212
you're wc bro
Hassan33317
found a fix for this issue. apparently i wasn't the only one having this problem.
https://www.sammobile.com/news/one-ui-3-0-battery-stats-2021-bug-on-galaxy-phones-fix
iarshad212
yes this is correct guidelines 👏
Shakir1
Charge you phone to 100% than either clear device care cache or factory reset. 100% is must
