Resolved! Solved
Auto rotation for Lock Screen can not be enabled in S23Ultra. Any solution?
(Topic created on: 04-04-2025 01:31 AM)
MhmdFaraz
Beginner Level 4
The button can not be enabled, any tip for enabling it?
aakashnawab7
You are using lock screen wallpaper service. Disabe that option, or apply some static lock screen wallpaper from gallery, then you will be able to turn On auto rotation for lock screen
6 Comments
aakashnawab7
It can be enabled.
Swipe down the notification panel. Press and hold the Autorotation toggle for 1-2 seconds. A second menu will appear. From there, enable Lock screen option.
aakashnawab7
MhmdFaraz
Beginner Level 4
Something is preventing it, and the button can't be turned on. 1743762615673.jpg1743762615715.jpg
aakashnawab7
MhmdFaraz
Beginner Level 4
It's done.
Thanks for your kind support.
Kind regards
aakashnawab7
Thanks.
If this solved your issue, kindly mark the comment as a solution.
Thanks
