Wifi connectivity Issue with Samsung Note-10 Plus
(Topic created on: 07-04-2020 12:31 AM)
asmh1982
Galaxy Note
Hi. Please find attached images for your information. Most of the time, My handset shows wifi connectivity error of signal quality. I found that its a **bleep** error which handsets shows whenever handset go away up to 20 meters , while other handset and devices on same location shows strong signal strength and remain connected with Wifi. It is not matter of particular place and wifi router. Its occurred everywhere on different routers as well. Finally, I learned that Samsung Note 10 plus has by default Wifi connectivity issue at the distance of 10 meters to onward. However it eventually rectify if once you fetch wifi key disconnect and then connect. It is my request to SAMSUNG team kindly rectify this issue one for all by sending update. Looking forward
Dr. Asif Munawar
Maggu
Galaxy Note
