Network Speed Monitor?
(Topic created on: 01-26-2022 01:41 PM)
musman5264
Galaxy Note
Is there any option to display network speed in status bar??? As such builtin feature?
Because 3rd party apps causes battery drain and ads etc.
So, is samsung able to do that??? Its an essential feature that uses like and want in their phone.
It should be in UI 3.1 and also in all upcoming updates.
There should be an update for all devices to display the network speed update.
Is it possible for Samsung developers??? Or they can't do that?
6 Comments
Mr_Yousufzai
Galaxy Note
Download internet speed meter bro its very lite and don't use too much of battery
musman5264
Galaxy Note
Yousafzai141 I already know about that, infact using it. But why its not in the stock features?
Mr_Yousufzai
Galaxy Note
Bro let me tell you that Samsung doesn't add potato features like other brands add. But instead you van use 3rd party apps
musman5264
Galaxy Note
Hahahaha POTATO FEATURE... 🤣😂🤣😂
musman5264
Galaxy Note
This isn't the rule of sales and Marketing... anyhow... I just posted a thread to let them know.... not for you brother... so take it easy...
musman5264
Galaxy Note
And as per my knowledge... its Android's Feature... and IF you think its POTATO feature then you mean GOOGLE is insane?... 🤭🤣😂
