Battery drain within 3 to 4 hours
(Topic created on: 07-25-2023 03:53 AM)
UsmanChaudhry
Galaxy Note
I have samsung galaxy note 20 ultra
My phone's battery drain very fast even without using and when battery percentage reached 30% then mobile is off and once i try to on it's already in zero.
Kindly suggest would be greatly appreciated your suggestion
6 Comments
Galaxy Note
Check Battery health in diagnostic
MalikDanish
Galaxy Note
It's look like your phone bettery is not in good condition, you have to visit samsung center or any other mobile repairing shop to resolve your issue.
Qamabb
Galaxy Note
I'm using note 20 ultra, how can I get the full specification of my phone
Qamabb
Galaxy Note
Need cover for note 20ultra
Galaxy Note
Man, did you update it recently? Because the July update has lots of issue including battery drainage.
Try to hard reset it if possible. You can use a smart switch for backup to an external device. And must wipe the cache partition.
MZYR
Galaxy Note
Battery is leaking current inside somewhere, battery need replacement. other possible cause could be charging jack is old or mishandled or have you ever got your phone repaired ?
