BATTERY PROBLEM
(Topic created on: 12-09-2019 06:28 PM)
SYED512
Galaxy Note
I have note 9,
Its consumed 17% battery while note in use,
Data and WiFi connection is off and its on
Medium power saving mode.
Please check other note 9 uders and please help me.
I plan to sale it and leave Samsung.
16 Comments
sarampervaiz456
Beginner Level 3
Galaxy Note
bro same probelm But i have note 8
FaizanFaizi
Galaxy Note
Dear brothers
this is due to heavy load of apps installed in your phones.
I'm also using Note 9. Some time ago I faced this issue. I simply made a factory reset and installed only those apps which I really need. No extra apps and games
Now that battery drain issue is no more
RasoolHamzaRao
Galaxy Note
Bro I'm also using Note9 from August 2018 and still I have no battery Issue.
Kindly install "Galaxy Labs" app which helps you to improve battery performance.
Abdullahoh
Galaxy Note
how to?
i can't find it in galaxy store
RasoolHamzaRao
Galaxy Note
bro in Pakistan this app is not available so you need to download it from APKMirror
SYED512
Galaxy Note
thnx all brothers
SYED512
Galaxy Note
Dear All,
do you think that battery life will be more better after Android 10 update
RasoolHamzaRao
Galaxy Note
No bro. I'm using Android 10 on my Galaxy Note9 and its battery drain is increased.
Uzairmalick
Galaxy Note
it is beta programming its was not orignal there are lot of problem in beta
