Sound problem
(Topic created on: 12-07-2021 07:16 AM)
LostInOblivion
Yarrr I have A51 and facing sound problem. Everytime when I play video/audio file, it doest not sound so I have to press volume up & down to make it soundful. I don't know how to make it proper operational?
Can anyone help me out?
2 Solutions
eyeshabutt
Go to settings and search reset all settings
Saadi121
Click on 3 dots and accept the solution please
21 Comments
eyeshabutt
Hmm by doing this, do not I lost my whole data🤔
SyedUsama1915
You may not lose ur data brother
You may do Reset settings
Do not click on Factory reset ok...
Alright brother. Will check it now.
Yup....ho giya ..sound problem retrieved by resetting. Thanks.
eyeshabutt
3 dot pa jaka.soloution accept kardo bhi
Es se kiya ho ga🤔
Saadi121
Thanks
Hello...I did not get my problem solved by reseting all settings...same going on...
