Sagarchawla72
03-26-2022 12:13 PM in
5 Comments
mz112
03-26-2022 12:28 PM in
Do check device care and optimise your phone regularly, I am also a52s user and I didn't see any battery drain or lag
Not applicable
03-26-2022 01:00 PM in
Thora sa lag kia tha after updating my A72 to android 12. Mein ny phir factory reset krdia tha tou ab alhamdullilah it's working fine. I haven't experienced any issues regarding battery drainage and mera phone almost 1 year old hy. Hosakta hy k apko weham ho 😅
iamhamzamalik
03-26-2022 07:48 PM in
Weham ni hai bhai same issue mere sath b hai or b bht sare logon ko ye issue a rha A52s mein
Sagarchawla72
03-26-2022 10:21 PM in
Bhai hosakta hai mera wehm ho lekin baki aur log jo yehi same issue report kar rahe unka kya?
Not applicable
11-24-2023 12:43 PM in
1-enable protect battery option
It stops charging at 84-85.
2-dont use fast charging option when there is no need.
Because it increase pressure on phone's battery.
3-dont use your phone below 15% battery remaining.
4-refresh your battery status by following below tutorial👇
dial*#9900# on your phone dialer
SysDump will open
Scroll down
Select battery stats reset option
and then click on exit.
SysDump will open
Scroll down
