3omarr
09-13-2024 01:18 AM in
جالاكسى S
7 Comments
AbdullahSamer
09-13-2024 01:28 AM in
جالاكسى S
When u say drains so fast .. how long it lasts ?
I got the same phone its been handi for 3m now and the battery lasts for at least 17hours
3omarr
09-13-2024 01:29 AM in
جالاكسى S
mine probably can barely last like 7 - 8 hours full charge
AbdullahSamer
09-13-2024 01:32 AM in
جالاكسى S
Whats ur brightness level ?
And do you game or just browsing?
3omarr
09-13-2024 01:48 AM in
جالاكسى S
the brightness level is like one third the full brighness and I do game but not much for the battery to drain that fast, I probably have less than 1 hour of gaming today and the battery lasted 7 hours
AbdullahSamer
09-13-2024 01:54 AM in
جالاكسى S
I dont know what do u mean by one third however i always keep my BR leve like that i only raise it when im outta home
But still 7 hours is not good
Always clean the background apps and dont keep them on
Always put you phone on dark mode
Keep ur BR level low if ur in a none bright place
Remove unused apps or put them to sleep
Make sure that ur screen resolution is at FHD not QHD
I also recommend to keep your profile performance at light mode instead of standard
Try those and see it should at least keep ur BAT 4 hours further
3omarr
09-13-2024 02:11 AM in
جالاكسى S
I do most of these but I'll try doing the light mode thing, thanks
AbdullahSamer
09-13-2024 02:13 AM in
جالاكسى S
That's something.. the bright mode makes the screen pixels on and that drains BAT , also set your wallpaper a dark thing
