Worst Battery Performance
(Topic created on: 10-22-2020 12:55 AM)
MAhmad99
I recently bought S20 FE 4g.
I am to much disappointed by the battery Performance of this Mobile. It is the worst battery Performance I had ever seen in Samsung mobile. Like you just unlock Mobile it drops 1%. You unplugged it at 100% and start using it in just 30s it drops 2% 3%.
It is even more worst when Mobile is heating up.
I feel like I bought a second hand phone/used phone. Dua to its battery and also heating issue.
Really disappointed.
Nawab_khan
did you reset your phone after update
MAhmad99
reset.. my all data is in it. i restart it.
Nawab_khan
would u like to share what thing is consuming battery at first place.. Go to Device care tab > battery > battery usage
MAhmad99
MAhmad99
I'm just using what'sApp and YouTube a little bit just watched 1 video of rahem pardesk. I unplugged it at 9pm on 100%. Now it's 11pm and my btry is 75% do you think this is ok? even I'm using 60hz display, wifi..
Nawab_khan
did u update all system apps of your phone ? we have to go ahead step by step..
MAhmad99
every app is updated from play store or Samsung store
MAhmad99
i don't factory reset my phone
MAhmad99
even bro i was playing pubg on this Mobile yesterday. it feels like i was playing on a 20k or 25k mobile.. i paid 120k for this mobile and performance is like 20k mobile..
I'm a Samsung user from 10 years and this is the worst mobile made by Samsung.
Nawab_khan
well..... 25 % drop in battery = 2 hrs.
              100% drop in battery = 8 hours (assuming)
it is not bad but average and you can improve it .
At first place, factory  rest your phone after backing up data. resetting phone is the solution of many problems particularly after updating.
Secondly, turn off unnecessary features which use phone sensors. ( there may be 42 sensor related features in ur phone) Advance features > motions and gestures
turn off wifi and Bluetooth scanning along location if it is not in use.
