Wifi 6 not detecting on s24 and s25
(Topic created on: 06-10-2025 01:38 AM)
Agrock
Hi, I recently purchased the TP-Link Archer AX10 WiFi 6 router and set up two separate WiFi networks: one on 2.4GHz and the other on 5GHz. I have a Samsung Galaxy S24 and S25, but both devices are unable to detect the 5GHz network. Initially, the S24 briefly connected to the 5GHz band, but the network disappeared shortly afterward. On the other hand, my laptop and Google Pixel 6a can consistently detect and connect to the 5GHz network without any issues. I’ve already tried the following troubleshooting steps: Resetting the network (WiFi and Bluetooth) settings on both Samsung phones Restarting the phones and the router Factory resetting the router Toggling the RAM Plus option on the Samsung devices Despite these efforts, I haven't been able to find a reliable, permanent solution. Any guidance would be appreciated.
14 Comments
user9992112
I had the same issue... worked fine on laptops but not on the phones
Agrock
I think issue is with tplink frequency or something as my both samsung are also from ksa
Agrock
Yeh my router is from ksa
user9992112
Exactly, these gulf routers are the problem
AmirJaved
Go to router's admin panel and change country to USA then go to 5G settings and select any 1 band from 149 to 161 , after save settings you can use 5G.
