Signal Problem
(Topic created on: 05-22-2024 01:24 AM)
Kashifasghar
Yesterday i updated my S21 FE to One UI 6.1 , later that night i started getting (Sim)Signal Problems. Like, there is signals on 1 sim and the 2nd sim is not having any signals(Emergency Calls Only). It becomes fine after Aeroplane Mode but after some time the problem appears again.
10 Comments
iizzuufied
Restart it
Kashifasghar
Already tried it
ShaheryarK
Gettings same.
Kashifasghar
U r having the same problem?
ShaheryarK
Yes bro. Tried everything. But none worked. Same msg showing No sim No service Emergency calls only
Kashifasghar
Which phone r u having and what is ur current Software update?
ShaheryarK
Yes. Ofcourse. Im using s21 fe 128gb. Ive recently updated to oneUI 6.1. I thought its a problem with sim tray.
Kashifasghar
Send Error Report to Samsung.I just sent it , and u should also so that they can take this matter seriously and have it resolved ASAP.1716385827913_1716385827906_0.jpg
DrMustjab
Fix one sim on 2G network in sim settings.
