S9 plus Auto Focus issue
(Topic created on: 09-25-2020 05:07 AM)
MalikNomee8
Aoa fellow members. I am using exynos S9 plus G965F/D running latest android 10 one ui 2.0 with April 1st patch. My phone has been constantly struggling to focus on nearby objects. Not just in the Camera app but also on Snapchat and Instagram. I thought it was a software issue because I had this on Android 9 with one ui 1.0. I thought update would fix it but android 10 update didn't. So I waited for latest patch but it still didn't. I haven't dropped this phone once. No sides are even scuffed and the phone is in a case. I have been reading online how Samsung phones, namely the s20s have been developing the same autofocus hunting issues. It's worse in video and photo mode can't seem to lock on even after tapping. Are you guys facing the same issue? The phone is out of warranty obvioulsy now. Your comments would be much appreciated. Almost 95 % pictures are blurry, I'm using this phone from android 8, and that not a single issue about camera. After updating to Android 10 all the issue of camera and screen begins.
13 Comments
arbabazhar
2.0 is not latest for s9 2.1 is
MalikNomee8
2.1 b krke dekh liya, same issue
MalikNomee8
check this bro
AliRazaShafi
try hard reset. and if it doesn't help, this may be a hardware issue. i also got s9plus. yeah Samsung has a shity focus but its not as bad as you described.
MalikNomee8
brother rest kiya tha, lekin hard reset nhi kiya, wo b krke dekh leta.
AliRazaShafi
han aik dfa try krlo. agr software ka issue hua to pta chal jayega nai to confirm hardware issue ha.
MalikNomee8
mere khayal se ho ni skta hardware, mobile boxpack liya tha, or 1 martba b ni gira wagera, or mere bhai pass b s9 plus hai to uska b same issue
AliRazaShafi
Samsung ka auto focus ka issue ha par itna b nai ha jitna apny btaya. mera b focus ka issue krta ha par 1 second ya is se b kam krta ha. usi time focus krleta ha dobara aur manual focus ka issue b nai ha.
aur mera phone girta hi rehta ha and i don't use covers and protectors.. 😄
MalikNomee8
Aap dubara note krna brother, sirf selfie me ye problem hai or kahi ni, selfie chahay snapchat, insta or camera etc kahi se capture kro to same issue
