S25 coil whine / static /sparking noise
(Topic created on: 02-27-2025 07:16 AM)
BilalZahid
Beginner Level 4
Is any one else facing this issue? When I put my phone to ear even when not on call I can hear distinct sparking sort of noise, it comes and goes some time during calls as well.
Really peeved about it.
4 Comments
NabeelAhmad
No such issue is faced.
If you are near to such device which transmit radio signals then may be this issue can be checked or judged.
BilalZahid
Beginner Level 4
My first thought was the same, I thought it was due to my galaxy fit 3 which I was wearing on the same hand and phone was near it
But afterwards I checked in several locations, with screen on and off and on and off call
Oktheorignal
Looks like someone got a faulty buck convertor
Try to reproduce it and note the conditions under which it happens.
gienku
I am also facing this issue, under heavy load, like benchmarking or photo processing or other activities I can hear coil whining. Under normal use I can't hear anything at all but sometimes when I stick my ear to phone then yeah I can distinguish some sounds coming from my phone. It's kinda frustrating because almost no one is facing this issue and I guess it will be hard to get refund or replacement
