Resolved! Solved
S24 Battery Timing
(Topic created on: 02-28-2024 07:08 AM)
arslmaqs
AoA Guys, I switched to Galaxy after 8 years and I'm not sure about the current battery ratings of new galaxy phones.
My S24 gave me ~6 hrs of screen on time on full charge. I am using 120HZ with Alwayd On Display (for new notification only). Using Face Unlock as well. Is it a good battery timing?
I feel that it is draining too quickly, and have a constant range anxiety maybe because I switched from a 6000mah to 4000mah??
Thank you in advance!
Fahad098
Search on youtube 26 tips for battery save
26 Comments
arslmaqs
wikkirajpoot
Quickly drain
Fahad098
Very good timing
arslmaqs
Is it? Abhi on 2 hours standby it has eaten 10% battery.
Fahad098
Always on display is on and what is brightness level and is there any animation or picture in Always on display and what is background usage when phone is off
arslmaqs
No animation.. it's just black AOD without picture.
Fahad098
Oh ok
Fahad098
How much memory is free
arslmaqs
200 GB
