S23 ultra battery drain
(Topic created on: 11 hours ago)
Sujee261
Beginner Level 4
Any solution?
2 Comments
Is this after the oneui 7 update?
Janith842
Restart your phone and enable battery protection functions. Turn off Always on Display, Decrease brightness by 10% and limit CPU to 70%. If the battery drain occurred after the One Ui 7 update. Wait till the next security update from Samsung. It will definitely fix the battery drain issue. Alot of users have the battery drain issue.
If my comment helped you in any way. Please consider hitting the 3 dot menu of my comment and accept it as a solution. It would be helpful for me a lot.
Thank you 😊
