Danyaal
10-28-2024 03:20 AM in
Hi everyone, I used my phone last night in a pool to record some videos and this was the 1st time I used under water, the phone was working perfectly fine and i dried my phone immediately after getting out of the pool! After some hours, i noticed some moisture one of the back camera lens, and then the moisture developed in all of the cameras, I turned off my phone over night, however the problem persists.
Has anyone faced this issue, and can give me a solution please? I am really worried, my phone is working fine, there is no problem at all, but my camera's lenses are not working fine. Please help!
6 Comments
aakashnawab7
10-28-2024 03:52 AM in
Turn off the phone, and take it to repair shop ASAP.
Samsung's phones are not waterproof, they've not even water resistant. Samsung use worst glue for their devices. Never use near water
Danyaal
10-28-2024 07:19 AM in
Thanks for your response maybe I should visit a repair centre now.
aakashnawab7
10-28-2024 11:22 AM in
I got moisture in Galaxy s7 not because of water, I was using it on bike in foggy days without cover. Display ribbon got moisture and in 2 weeks display strip got rust and fungus which bacame unrepairable and I lost complete display panel.
A52s I'm using. I didn't even used this mobile signal day without complete wrapping + back cover. And last month I saw that phone back is detached completely automatically. It just got detached automatically. I was amazed to see that.
I googled and found that Samsung use worst quality of adhesive strip for their devices. You can just Google and see people reporting this issue.
I went to Samsung official through some strong reference and you will not believe that Samsung representative asked me to get it repaired through unofficial shops as He said Samsung will again use this bad adhesive strip and you will get same issue in less than 1 month.
So remember one thing. Water resistant is not waterproofing. And Samsung's water resistant is just a gimmick. Never use Samsung device near water or moisture.
Only apple provides good water resistant that works well. Samsung is far behind in this thing.
EmmanuelA255G
10-28-2024 04:39 AM in
I have washed my A54 5 6 times thoroughly with water but still nothing happened
Danyaal
10-28-2024 07:20 AM in
Woah!! As mentioned, my phone is working perfectly fine, there's just some water inside the cameras lens which i am not able to take out and it's not going away!
Arshad_Ali_S21u ltra
10-30-2024 03:12 PM in
Samsung apne maeyaar ko kharab karaha hai
Mere pas s21 ultra hai uska back thora khul gaya hai jiski wajh se cameras k lens k andar thora dust aagaya hai
