S22 ultra got white vertical line is that a problem with display
(Topic created on: 10-30-2024 06:31 AM)
Raider_Abhi
Does anybody know how to resolve the white line issue its like 2 year mobile s22 ultra god why is this happening any idea
5 Comments
Hi, in case you aren't aware, lines of pink, green, and white have started showing up on multiple phones of Samsung, One Plus, and even iPhones. This is associated with the heat the phones generate. Unfortunately, there is nothing that can be done to resolve it from ur end. You need to take it to a shop that can replace the display for you.
If my comment helped you in any way, please consider hitting the 3 dot menu and accepting it as a solution. It helps me. Thank you!
Raider_Abhi
Yes but before update it wasnt heating that much now after update its heats up very frequently so its their fault right i didnt drop or damaged my phone. I now feel very much disappointed with samsung never ever gonna buy flagship phones ... i lost trust samsung...
I'm sorry to hear that. Hope your next phone will be better.
silentk27
My S23 got a pink line last month. Samsung is asking 80k for the screen replacement. There’s no physical damage, and it appeared out of nowhere. I have been using this device for only 1 year and 2 months. I will never buy a Samsung again. I know this issue exists with other manufacturers too, but it’s too obvious that significantly more Samsung devices get this issue compared to others.
Raider_Abhi
Yes dont know what samsung is doing they are making a scam i think because for flagship device to last 1 year or 2 is not a good thing i m also using s22 ultra and suddenly a white line came. I have realme  2 pro also which is upto date still running good. Specially heartbroken with this kind of issues. Hope you get some better resolution from samsung
