S22 network signal problem
(Topic created on: 03-16-2025 01:20 PM)
sungguy
Hello Samsung Guys,
Hope you are doing well. I want to ask you about this problem that I'm facing. I've been having network signal issues with my Samsung S22 since I got it. I've tried every setting and done multiple factory resets and wiped the cache partition, but nothing's worked. My SIMs work fine in other devices, just not this one. Have you heard of this issue, and can you help me fix it?
5 Comments
Ebxxd
This is not an issue, Samsung has not yet released the March Security Patch for Galaxy Devices except S23 Series as they are getting One UI 7 Beta
sungguy
Then why is this happening in the first place? This is really annoying 😑
Ebxxd
Samsung hasn't released the update yet.
It is yet to be released
This is not an issue with your phone.
sungguy
Hey Bro,
I updated my device to the latest security patch, but still, I'm facing the network signal problem. What would be the possible problem according to you? 1742405000932.jpg
Ebxxd
Hmm, this is quite odd.
Try contacting customer service or a certified Samsung mobile store
