S21 video recording sound issue
(Topic created on: 03-01-2023 07:44 AM)
zeshan14
My s21 fe makes a slight prring sound through out the video recording.
256 gb exynos model. Got brand new from Samsung online , 6 months ago.
Is it a software issue? I think it happened after some update maybe.
15 Comments
USMAN381
You got android 13 UI level 5 ?
zeshan14
Yes. Android 13 , ui 5
USMAN381
If it is done you are absolutely right its sofwear issu
zeshan14
Update should fix?
USMAN381
Yes dear wait for android 13 UI level 5.1
zeshan14
Thanks bruh
USMAN381
Dear if you accept the solution please click 3 dots and accept solution resolved and follow please Jazak Allah.
zeshan14
Dude?? Wat r u getting at?
zeshan14
Bugger off !!
