S20 FE overheating issue
(Topic created on: 02-12-2021 11:26 AM)
ZubairKhan1
I bought S20 FE 4G model, the device is getting very hot at the top, camera area being most hit. this is certainly while getting everything setting up and charging at same time. But the heating has not reduced for almost 2 hours. mine is Exynos 990, 8GB, 128GB variant. Please provide the solution as it looks like, I hold iron in my hand.
13 Comments
Ikrmahassan
Heating issue is common in exynos 990
ZubairKhan1
is this overheating create any big issue ?
Inamullah
yes
zeeshan487
same is with s21 ultra.
only waste lot of money
Ikrmahassan
May be lagging issue happens in prolonged gaming otherwise its fine for normal usage.
jawadh
yes exynos processors are notorious for overheating.
so whenever it overheats, it reduces the performance to keep the temperature normal.
don't play games or put too much load on phone while charging.
Inamullah
sell it immediately!
Omer69
bro you don't need to worry if your phone is heatup for some time its normal behaviour of your phone.......
Omer69
1 thing more if your device is not consuming battery then your device is okay... agar heatup kay sath battery consume krta ha to problem ha.....relax and chill rahay...
