Problem with touch of Galaxy S22
(Topic created on: 04-30-2022 06:40 AM)
RajaMameen
I have purchased S22 Ultra day before yesterday, I face a problem that some time it's touch screen become irresponsible when touch to tap or zoom or zoom out any pic with a pinch, is it a software problem or other ?
12 Comments
malilodhi
Its software issue, same issue appeared on my A52s but thankfully after 4.1 its 99% clear, but before 4.1 i have made some changes which almost worked 100%.
1) changed fps from 60hz to 120hz if its set on 120 then change it to 60hz
2) clear cache memory from reboot menu (by pressing volume up and power button when phone is switched off ) you can see through youtube videos
3) optimization of apps from same menu
4) if nothing works then from same menu there is factory reset and do that ( pls take backup before doing this Nd dont do factory reset when phone is switch on it wont work)
RajaMameen
This problem was also before installing screen protector, I have done every thing but problem is still there, now I am in tension that what is this with this flag ship device, I am also searching that how can I know that it is software problem or touch screen problem
djmalik
Well i have faced the same issue.. as i have replaced the phone 2 times and got the same issue.. now m waiting for the new phone .. my brother is also facing the same issue.. its a software bug and hopefully it will be corrected soon with firmware update
