One UI 2.0 Edge Lighting Issue
(Topic created on: 01-17-2020 09:29 AM)
MunirKhattak
I've upgraded my Galaxy S10 to One UI 2.0 based on Android 10 few days ago, Now I'm trying to enable the new Lighting Effects (Firework, Spotlight etc) for the Notifications but no effect is working. Any solution for the Issue please 🙏
No effect with notification while I've selected the effect.
14 Comments
kya aap screen reading kr k snd kr skty hyn
MunirKhattak
screen recording?
working for me.... just check out the settings
comments mn video share Nahi Hoti
MunirKhattak
share your settings for, please. how to set the settings for it?
illu123
just select and it will work some times it will not show the preview
njejani
Beginner Level 3
same problem for me.
S9 plus
suzanumair
yeah I'm facing same problem the lighting style is not working...
suzanumair
just now I've sloved my problem you can try too if you want too..it will help you you just have to go in phone setting then go developer option and find the animation scale and then you will see if it would be off you just turn on 1x or if it's on 1x already you just set on 5x ok..hope this will work for you...reply me does it work or not
