LOCK icon issue
(Topic created on: 09-13-2025 12:21 PM)
Baqs1214
I can't change my lock icon on lock screen on s25 ultra
Please suggest a solution.
4 Comments
RIP-CSGO
Install Lock star from Good lock
UmarFarooq11
I'm not sure that it will help or not but try changing lock screen clock style and font, and also the phone font
ẅăĺéëď
You can change it from lockscreen
BAHLOO
Brother you need to first install good lock then a module called lock star then you will need to activate the module then you can change from lockscreen easily
If you found this helpful please click resolved to support this community
