How to enable swipe gestures (Swipe from bottom, Gesture hints) on the Galaxy S24
(Topic created on: 05-22-2024 10:12 PM)
Global_Contents
With the new update to the navigation bar settings on the Galaxy S24, the Swipe from bottom and Gesture hints options have been simplified but can still be enabled via Good Lock's NavStar app.
Notes:
  • Effective for NavStar app version v6.1.05.33 and later.
  • The Good Lock app supports English, Korean, Japanese, and Simplified Chinese.
Download Good Lock and NavStar
By installing Good Lock’s NavStar app, you can further customise your Galaxy S24 to suit your preferences.
Step 1. Download the Good Lock app from Galaxy Store.
Step 2. Open the Good Lock app > Download NavStar in the Make up tab.
Enable extra gesture settings
When you activate the Enable extra gesture settings option in the NavStar app, you can see the added options in the navigation bar settings in Display.
Step 1. Open Good Lock app > Tap NavStar in the Make up tab.
Step 2. Tap the switch On to enable extra gesture settings in the Swipe gestures tab.
Set up the Galaxy Swipe gestures (Swipe from bottom, Gesture hints)
After enabling Enable extra gesture settings, additional options appear, such as Button order and Gesture hints.
Step 1. Open Settings > Display.
Step 2. Tap Navigation bar.
Step 3. Select Swipe gestures > Tap More options.
Step 4. Select the desired swipe gesture and button order.
Step 5. Tap the Gesture hints switch to enable the feature.
Last Update date : Feb 07. 2024
Ap k pass kon sa phone haa or kis traa use kar rah good lock bata sak ta hn
balocha
SAMSUNG GALAXY +8
SAQLAIN11E
Beginner Level 3
good 😊
fishe
Very nice
strugel
Hood
Miansaib933
It's to easy for us
sial77
Beginner Level 3
Thank you
TahirSahibzada
Beginner Level 3
Wonderful thank you
Afazsheikh
I have A70
razmuhammad5512
Hi
