Facing Problem
(Topic created on: 11-23-2022 04:52 AM)
Yasir919
I had to reset my phone (Galaxy S22+) but when it was reset, Google Play Store has disappeared. Even it is not available in Apps section. I've tried everything but nothing worked, then I went to factory reset again but thats disappeared too, then went to hard reset through recovery mode but the option to hard reset has disappeared too. Need help
5 Comments
mroshaanumar
Your best bet now is to contact Samsung themselves.
Head over to www.samsung.com, scroll all the way down, and you'll see a support section.
Choose the option that suits you best.
Hope this helps.
DrShahid
Bro esi trah samsung Ka aik cell tha us Mein Google play ghaib tha Mein ne net se Google play store apk file Mein kr liyA now it's working well... Itna ZiydA ap ne us k sath pangy Le liye
aakashnawab7
Is your device is rooted ? I think so.
Contact Samsung Service Center for software flashing.
Yasir919
Not rooted dear
Yasir919
After reset the phone, Google play store, finger lock, face recognition and reset option has disappeared
I m also unable to change the wallpaper or apply some theme
