Charger for s25 ultra
(Topic created on: 03-20-2025 12:49 AM)
Alim11
Will using 25 watt original samsung charger effects battery life of s25 ultra if not using 45 watt original charger?
13 Comments
deathxrvng
Just use the original 45w
Alim11
Any specific reason for this?
deathxrvng
Not really. But Samsung never made anything higher than 45w so I'm assuming that's for a reason. You should also be ok with an original 25w but it's just going to be very slow.
Alim11
Just saw comparison video on yt and difference is of only 13 mins while 25 watt isn't heating phone that much so I'm assuming less heat may increase battery life
deathxrvng
Idk man I'll choosee the 45w. I don't think it'll effect the battery too much. Before s25 I had Xiaomi phone for 5 years with a 44w charger and it's battery is still amazing.
ASIM-ANSARI
Selling original 25w charger brought from Samsung service center 20240628_230923_1000006476_1742037083.jpg20250317_104032_1000006683_1742190032.jpg20250317_104038_1000006684_1742190038.jpg20250317_104050_1000006685_1742190050.jpg
Moaizam
I bought 45 watt charger in 4500 pkr . Its working perfectly 👌.
Also showing super fast charging 2.0
ASIM-ANSARI
Show pics
Moaizam
Check it.20250321_071156_1000076753_1742523126.jpgIMG-20250321-WA0019_1000076754_1742523285.jpg
