Charger for S24 Ultra,
(Topic created on: 02-20-2024 06:54 PM)
Usama222
Can i use Oppo 45w charger for S24 Ultra or what is c×c cable concept? is it necessary to use only c×c data cable with S24 Ultra? also recommend which adapter should i opt for S24 Ultra along with cable inside the Box.
8 Comments
MuhammadS
Thir is no issue by using other brands chargers if quality is good .. c plus c both side are c type one is for charger and other is for cable .. 45w can charger ur mobile faster ..
Usama222
can i charge from normal charger like, Usb to usbc?
MuhammadS
Yes u can but it will charger slower m why dont u hav samsung orignal charger ?? ..
Usama222
it is unavailable in the market
aakashnawab7
No, oppo uses different voltages protocol for their charger, don't use oppo's one. Otherwise your device will charge slow as oppo provides VOOC technology and Samsung uses Super and Ultra Fast charger technology.
And as far as the C to C concerned: Upto 15W Type A to C cables are made and Above 15W, type C to C cables are used.
aakashnawab7
Read all the comments of this post, i have explained about charging protocols.
https://r2.community.samsung.com/t5/Galaxy-A/Samsung-galaxy-a32/td-p/15540292?src=ShareByUserCM
Saam_just_u
Oppo charger depend on woo charging so must need to use samsung charger so it will help you to get super fast charging 2.0
Zarrar26
Samsung mainly uses pd charging, which is only possible by a charger with type c port. Any charger with type A connector will not charge any samsung phone at more than 15w.
