01-31-2024 10:10 AM in
Galaxy SI have samsug s23 ultra and I am facing a problem with the battery draining in the night
Whatever I do even If I turn off the wifi and the AOD and activate the power saving the battery will be drain 15% until the morning (6-7 hours)
What should I do to make it better?
01-31-2024 10:13 AM in
Galaxy S- Mark as New
01-31-2024 10:21 AM (Last edited 01-31-2024 03:32 PM ) in
Galaxy SThe reason may be;
-It is time to change the battery.
-The battery has been damaged.
(If my solution worked for you, you can mark it as a solution 😊)
01-31-2024 01:42 PM in
01-31-2024 03:31 PM in
01-31-2024 11:39 AM in
01-31-2024 12:23 PM in
