Battery drain
(Topic created on: 11-23-2024 09:05 PM)
geemantha
Hi all,
After the october update, my S23 battery is train so fast actually i can use around maximum 4 hrs and its heating like an iron. Other phones also had same issue? Even i didn't get november update also.
Is there any option to downgrade this or move to i phone is better ?
#s23
#samsungs23
#flagship
#issues
#error
3 Comments
Have you tried simple things like restarting the phone? Going to device manager and clearing RAM, booting into recovery mode, and clearing cache? Try these simple steps first. If none of them work, consider factory resetting the device. These things are common after updates. But isn't usually a long-term issue
If my comment helped you in any way, please consider hitting the 3 dot menu and accepting it as a solution. It helps me. Thank you!
geemantha
I did all except reset. Because i noted since i updated the last version i am waiting for new update even i didnt get november update also. The thing is when i work battery drain fast if i don't use even 5-6hrs battery will reduce 2-3% .
Hassanali--
Force in order to get another new model phone, all phone companies will reduce the performance of your current phone by updating it. Many people will not notice this. That's why our phones will lose battery and performance in a few days due to the update they give.
