Battery drain after android 12 update .
(Topic created on: 11-21-2021 12:42 AM)
Talha311
I've notice that my s 21 plus is draining alot more battery after new update to one ui 4.0
Is it me or does anyone else is facing the same issue ?
6 Comments
No bro don't use Google maps location or youtube then check difference
Talha311
Well, I'm not using both . What screen on time are you getting ?
Bro syn functions is off also
Mani2001
Beginner Level 5
Same problem s21 ultra
samadbaig
Same issue with my s21 ultra
Mei Jin
Beginner Level 3
I'm facing the same issued too with my brother and cousin. we are using Samsung s21 plus after update UI 4.0 Android 12 battery drain very fast. please help.
