Battery Status ๐Ÿ”‹ weak
(Topic created on: 09-28-2024 05:38 AM)
abuthahirsihabaakil
What is the solution?
No brw still weak status and very heat ๐Ÿ˜ฌ
Is it a exynos version, can i know the model number?
Yes, brw exynos , SM- G985F/DS
Ah that's why the extreme heat, and did you play the heavy games on it while charging
No, brw , I'm not playing games
So that might because of extreme heat of the chipset so, generate lots of heat means it consuming lots of power to power the device๐Ÿ”ฅ.
As a time passes it damaging the battery health or battery cycles.
So there is no any other way to ovoid this issue you need to replace the battery ๐Ÿ”‹
Then of course you must to follow these tips for ovoid future issue
1.go to the power saving mood then you can see 3 things on it. On these settings
*limit CPU speed to 70%
*decrease brightness by 10%
*limit apps and home screen
2.use dark mood
3.use brightness level between 0%-30%
4.turn off Auto rotation
5.If you use mobite data change to the wifi
6.turn off bluetooth and some unused options.
7.if you have lot of unused apps, zip or sleep these apps
And
Remember to give a rest to your device
So if my comment is useful to you, use the 3 dots in my comment for accept my comment as a solution. ๐Ÿ˜‰ ๐Ÿ‘
Normally, is it heat brw ๐Ÿ˜”
Vishvar
Try clearing cache partition in Android recovery mode and check it again and also try checking with AIDA64 or CPUZ-ID, if those apps also report the same, this could be most likely a software issue in the phone.
Oky , but the phone is also very hot to use
I checked cpuz show battery health good ... next what i do ?
