Battery Status ๐Ÿ”‹ weak
(Topic created on: 09-28-2024 05:38 AM)
abuthahirsihabaakil
What is the solution?
26 Comments
Vishvar
How long since you bought the phone? Verify the battery status with apps like AIDA64 or CPU-Z, if it says the same, then I think you need to change the battery.
I have 2 s20 plus .. other battery is good so I changed that battery in this phone but so weak status ๐Ÿ™„ ...
Hi.. What's your device?
S20 plus
No way, how's your average usage
4hr per day
It might be a error, did you reset the device once or not
Yes brw reset the device
changed anything?
