Resolved! Solved
Battery Drain issue
(Topic created on: 06-10-2025 10:39 AM)
Zhakeel
I have Severe Battery Drain issue after one ui 7 update in my S22
How do I fix this issue?
https://r2.community.samsung.com/t5/Tech-Expert/How-to-Fix-Abnormal-Battery-Drain-amp-Micro-Stutters...
Check my previous post about this, if this comment helped you in any way please consider hitting the 3dot menu and accept as a solution 🙏
2 Comments
AnushaD
I have drained this much of battery in less than one hour screen time. Is this normal?? 🤔 1749609240603.jpg
