Battery Drain even Wiped Cache
(Topic created on: 05-03-2025 01:03 AM)
abubakarsehraai
I have noticed a slight more battery drainage after update to One UI 7. I wiped cache partition but still issue has not been resolved but hopefully it will be fixed in upcoming updates. I have S908U Samsung S22 Ultra.
3 Comments
FawadKhan633
I also update my S24 Ultra i m facing battery draining issue
Don't panic , it will take about two weeks to optimize. My battery even lasts longer than ONE UI 6.1 Now. 👏
FawadKhan633
Thank you dear
