Add problem.
(Topic created on: 11-16-2024 05:56 AM)
amar478
Hi everyone,
I hope all of you are fine by the blessings of almighty allah.i just need your help guys.i am using samsung galaxy A20 while I am using my device to many add are appeared on the screen.so please anyone tell me the solution regarding this issue.
Thanks a lot.
3 Comments
Ramzan885
Ok Let's Fix This Go to settings and click on apps where all apps are located click on view all apps then find the app which has no app logo like facebook app have blue fb logo if you find that app that doesn't contain any logo just uninstall it thats easy i have the same issue or plz dont mind my English 😊
amar478
Bundle of thanks bro.much appreciated 👍👍👍
rzer15
You can also try getting an adblocker, Galaxy store muss have at
